generator/inverter
Discussion in 'Beginning RVing' started by Steelie, May 12, 2016.
  1. Steelie
    Steelie New Member
    Recently purchased used 2013 Jayco class c. Had to have some work done on the generator, it is up and running, but when I have it on I can't get the a/c to work. Everything else seems ok, but the a/c will not come on. Do I have to do something when trying to run it off generator? Works fine on shore power. Also, what is the inverter all about? should I have it on and operating all the time when using the rv, or should I only turn it on when I need it to run something off battery?
