gmc/yukon towing citation
Discussion in 'Talkback' started by bendo60, Oct 13, 2001.
  1. bendo60
    bendo60 New Member
    have 2002 yukon with large engine
    will be towing a citation 33ft about 8000 lbs
    is this a marriage made in heaven
    2. any info on hensley arrow antisway system
    i know it is expensive.
    is it worth the price of 2650.00
    or is what the dealers put on good enough>
    rhanks
    e_mail me direct
    bendo.bendo@verizon.net
  2. C Nash
    Bendo,
    3000 lbs sounds kind of light for a 33 footer. Is this the dry weight? Remember you will probably end up with around 2000 to 2500 extra lbs of load when you put everything in the trailer. The hensley arrow system is worth the money IMO. What size motor does your Yukon have and what axle ratio? Does it have the towing package, trans cooler, oil cooler, heavy duty suspension. Check with your local dealer about the tow capacity or there are places on the internet that will give you the info. Don't remember the web add. Good luck
    Chelse L. Nash
    fulltimer03@yahoo.com
  3. HIHAUL
    HIHAUL New Member
    bendo,
    do you have yukon XL or yukon/tahoe size. i have z71 2001 tahoe
    tow/pkg 7700lb tow rate. ipull 2001 26t widerness t/t dry weight of
    5200lb and i thought i was pushing it a little.
  4. C Nash
    Bendo,
    If you have the Yukon XL 2500 with the 8100 engine, 3.73 or 4.10 rear axle you should be in good shape. Tow rating on this vehicle is 12000. The 1500 with the 5300 engine is rated around 8600 with a/t and 4.10 axle. XL 1500 around 8800.
    Chelse L. Nash
