GOOD WRITE UP ON TIRES AND PRESSURE
Discussion in 'Talkback' started by Triple E, Jan 22, 2011.
  1. Triple E
    Triple E Senior Member
  2. akjimny
    akjimny Senior Member
    Re: GOOD WRITE UP ON TIRES AND PRESSURE
    Good article. I didn't know parking on concrete was bad for the tires. I purposely put concrete pads in my yard to park on because we have some pretty aggressive grasses and weeds down here in Florida that will grow right thru almost anything. Maybe I need to put some pressure treated plywood on the concrete pads??
    Thanks for the heads-up Steve. :) :)
  3. H2H1
    I have mine on 2 x 12 x 24'' long, they are on concrete. I did this to level it up ,not know it was bad for them to be on concrete.
  4. Triple E
    I knew about having a barrier under the tires but I never would have thought about the ozone coming off of a transformer or electrical engine. My generator is between my two front tires.
  5. vanole
    vanole Senior Member
    Triple E,
    Just back from my abbreviated snowbird foray into Florida. Next year going to stay until at least April
    That was a good article you linked folks to.
    My former neighbor who is a tire fanatic (who also owns a motorome) was in the same campground in FLa as I. He passed me a snippet from and unknown source. Here is the snippet in its entirety "Tire Protection I have found the perfect pad to put under my motorhome tires to help protect them in all types of weather. It lets the tire breathe and eliminates flat spots. it is a thick rubber anti fatique commercail pad that is preforated and mesures 35.8 inches wide and 38.5 inches long. I have found the mat in several home improvement stores for $19.99 each. I bought two mats and cut them in half for a perfect fit under the front and dual rear tires. A $40 investment to protect six tires that cost $300 each is a solid investment."
    Needless to say he dragged me along with him to find these mats. Found them at HD. They are quite heavy and I think they will be a bear to cut and holy smokes they got a very strong rubber smell if you leave them in the car to continue shopping elsewhere.
    V/R
    Jeff
  6. Triple E
    I have been using the plastic bags that the salt for my water softner comes in. I like your friends idea more. Do you remember what the rubber pad is called?
  7. H2H1
    better yet, where in HD should one look for these pads. Our HD is a hugh store, so a little guidance would help. Thanks
  8. akjimny
    Now I gotta remember this next time I go to HD :eek: :eek: :laugh: Damn teflon brain cells. :) :)
  9. vanole
    My neighbor had to ask a clerk where they were located in this particular HD in Miami. Found them near the ladders etc.
    I've seen them here in Va Beach at the end of the aisle near the tools and have seen them near the flooring department also. Do not be fooled/tricked into them sending you to the lawn/grill section for a grill mat. These are not anything close to the toughness of the real thing.
    These things look like industrial strength rubber welcome mats.
    If you can't find them let me know and I will see if my former neighbor can get a SKU # of the ones he purchased.
    V/R
    Jeff
  10. H2H1
    Thanks Jim and Jeff, I willbe waiting on your reply.
  11. C Nash
  12. Triple E
    You might have it Nash. Accept these are $10.00 more and seem a litttle bigger then what Jeff spoke about. I guess we just have to wait and see. :approve:
  13. TexasClodhopper
    I cut strips out of an old rubber pickup bed liner using a jig saw.
    I cut the front ones long enough to put my orange leveling blocks on. I can drive onto the rubber mat and then onto the levelers. That way the levelers won't scoot out in front of the tires on slippery surfaces.
  14. vanole
    I have not be to HD here in Va Beach yet to see if they still stock these. However I called my friend down in Miami and he pulled one out of his cargo bay and read the data on the sicker to me. "anti fatique commercial mat, made in china, 1/2 in thick and it had a number NOT sure if it is the sku 136069"
    When the weather gets a bit better I will venture out to see if I can locate them.
    V/R
    Jeff
  15. Triple E
    Thanks Jeff. Is it the same as what Mr. Nash found?
  16. vanole
    Steve,
    No not the same as what Nash found. I just came back from the HD here in Va Beach. The mats are on the back wall of the store in the flooring section.
    I found a sales associate that had one of those calculator looking things that you punch in a SKU and it can tell you if item is still sold and if the store has it in stock and if so how many. The sales associate plugged in 136069 (provided in earlier post) and said that its a valid sku and they had 14 in the store. I walked back to aisle 26 in flooring and there they sat on the back wall.
    Now the good news price is now $17.97 vice $19.99 as stated in the snippet provided by my friend. After looking at the snippet closely I think the source is Highways Magazine.
    V/R
    Jeff
  17. C Nash
    I put that number in HD search and comes back can't be found :(
  18. vanole
    I did the same thing yesterday and nothing came up. That was the reason for me going in person seeing how I had a hand in starting this mess. However when I went to HD this evening like I said the sales associate entered that sku number into his calculator looking thing guess its some type of inventory control device and bingo its valid. I do know that I've had issues with HD and sku's in the past when I've looked at their online store for portable power tools particularly porter cable products.
    Jeff
  19. nifty9
    nifty9 New Member
    RE: GOOD WRITE UP ON TIRES AND PRESSURE
    The rubber horse stall mats or used conveyor belt work well and cheep.In storage I use 1/2 inch plywood no cost .When dry camping we use Crofton carpet under the whole Dp 42x20ft Real name is dryer felt that comes off the pulp mills lets water go through but no weeds will come through keeps your coach clean.Cost is 15 cents per sq ft getting harder to come buy with mills closing and more people rving in seasonal spots.As a contractor how has worked at running the construction of a store in Canada the store associates here are not the most knowable persons .Just my past experience.
    2002 Dutch star
    01 Dodge dually diesel
    59 chev short box
    31 Model A chopped coupe
  20. H2H1
    Hi Dave, I see you are a contractor, there fore I would thought you would have a poured concrete pad for storing your RV. I still think it is better to store on concrete than dirt. I keep mine on concrete with each tire is on 2 x 12. I have heard of some class A RV'er use there leveling jack to raise the tire off the ground and store it that way. I don't know if that is good or bad, but just the weight of the rear end on the jacks would some how damage them, but that my opinion.
