Headlights on 1984 Southwind
Discussion in 'General RVing' started by BenW, Jan 21, 2007.
  1. BenW
    BenW New Member
    Headlights went out.....when I used the dimmer switch....Anyone know where the headlight fuse is located or have any ideas...what the problem might be other than the fuze...Thanks...Ben
  2. Texas_Camper
    Texas_Camper New Member
    Re: Headlights on 1984 Southwind
    A short in the dimmer switch????
  3. s.harrington
    If your head lights are burned out on the high beam element they will not work except on low beam or if both low beam elements are burned out they won't work except on high beam. Also headlight relay may need replacing.
