Heating system
Discussion in 'Talkback' started by Rpd2978, Sep 14, 2014.
  1. Rpd2978
    Rpd2978 Junior Member
    Does the battery have to be good for heating system to work if plugged into 30amp outlet shouldn't the inverter or converter make it work if that's working I bought a new battery then it worked I have a 2012 Jayco white hawk
  2. C Nash
    have you checked to see if the converter is working?
  3. Rpd2978
    No I did not its still under warranty but I brought it in last year for the same thing and they said the battery needed to be charged I had three lights on the battery indicator out of three it's at the shop now but I was just curious if anyone new if you needed a good battery if your plugged into electric
  4. Rpd2978
    Sorry I didn't finish good battery for heater to run the igniter didn't click and there was no fan
  5. LEN
    LEN Senior Member
    Short answer is yes needs good battery or 12 volt power. But even a weak battery and hooked to 30 amp with the inverted working the furnace should fire up and fan should run. The fan should run any time the furnace is called for even with low batterty but the ignitor may not run untill the fan runs fairly fast.
  6. Rpd2978
    Thank you for the answer
