Holiday Rambler 2005
Discussion in 'Class A / Diesel Pushers' started by capt paul, Jul 29, 2017.
  1. capt paul
    capt paul New Member
    Does anyone know how to find and change air drier on 05 Holiday Rambler Neptune engine air conditioner?
  2. C Nash
    Capt Paul, if you are talking about the AC drier that goes inline on ACs it should be right around the condenser.
    capt paul likes this.
  3. capt paul
    now i cant get the compressor to engage.' brand new one
  4. C Nash
    Time to get the VOM out and start tracing back. Sure you have checked fuse and if it's a new compressor I assume it has full charge Freon. Should have a low pressure switch or thermostat just start following wire back from compressor clutch coil. Have you checked to see if 12 volts are at the clutch coil?
  5. capt paul
    thanks for the help. found faulty (brand new) compressor. should have checked clutch before installation. understand this is quite common.
  6. C Nash
    Never assume just because the part is new it's ok Capt Paul. Mechanic nightmare bad new parts and you have to replace for nothing if it's a customer.
