How to Fix Rv roof leaks
Discussion in 'Beginning RVing' started by lisawilliams123, Jul 15, 2015.
  1. Can any one tell me about DIY solution for fixing roof leaks in my RV? Waiting for your positive response.Thanks
  2. C Nash
    Where is it leaking? What type roof do you have , rubber, aluminum or fiberglass Need more info?
  3. Emma Brian
    Emma Brian New Member
    Liquid Rubber Roof Coatings by EPDMCoatings is the DIY solution of RV roof leaks problem. You can get more information by visiting liquidrubberroofing blog. Thanks
  4. Gary King
    Gary King New Member
    Rubberized leak stopper are available. That will be of great help in fixing roof leaks
  5. Isabella John
    Isabella John New Member
    You can also check Rvliquidroof.net for all about RV roof problems. Thanks
  6. nowhereman
    nowhereman New Member
    M y A/C rotted my roof, I used this rubberized stuff and it seemed to work fine. Good luck.
  7. Jonathan Merage
    Jonathan Merage New Member
    As mentioned by other members rubberized stopper is a good solution to fix leaks in your RV.
  8. Isabella John
  9. flownaksala
    flownaksala Banned Users
    All RV roofs will leak at some point. You should check the roof at least once a year. Fix any leaks immediately because they can cause A LOT of damage. In my opinion the Best solution is to use Eternabond tape. It lasts forever and is easy to apply. Make sure to get the wide version (5 or 6 inches wide). You simply clean
    the application area with a cleaner and then apply the tape over whatever is leaking. This is a permanent fix. This is the only stuff I use and I've never had a leak reoccur after using the tape. You can get it on Amazon. It's also a good idea to keep a detailed vehicle maintenance log for all the maintenance and repairs you make on your RV so you know whats been done and when. I use Automotive Wolf car maintenance software to manage the maintenance on all my vehicles including my boat and even the generator. Its easy to use and sends reminders when anything is due to be checked or replaced.
  10. SCcamper
    SCcamper Junior Member
