Location Converter Box
Sunnybrook27FKS
I have a 2001 Sunnybrook27FKS Scout and I need to check out my converter box.
Where did the manufacturer put it?
Anyone Know? Need Your Help, Thanks
Grandview Trailer Sa
Re: Location Converter Box
I am not sure about 2001 models, but current models do NOT use converters....
There is a better way and SunnyBrook does it! Current models have 12 volt fuses with the battery disconnect...Your 120 volt breakers are in a Square D elec. box...your charger is in the storage area in a 5th wheel or under the sink in a trailer. These 3 items make up the converter, but a much better system. You will never have problems with the Square D box or the 12 volt fuses. The charger has it's own fuses and is very reliable.
