Macerator pump
Greetings,
Just picked up new Roadtrek Adventurous and drove RV back to Jackson Hole from MN, but didn't use plumbing. Once home in Jackson I filled black and grey tanks with water to test system. I opened grey tank value [pull out] and turned on pump by pushing button located next to drivers seat - no water pumped out although I can hear pump running. I then pushed in and engaged device to free clogged pump. It turns with just a little resistance. Still no luck. I hate to drive unit back to dealer to get fixed - not sure if something is broken or I'm I doing something wrong. Help appreciated.
akjimny
Re: Macerator pump
Hi Jeff and welcome to the forum. I can't help with your question but do have a suggestion. You might want to repost your question on either the Beginning RV thread or the Class B thread where more people can see it and come up with an answer.
