map of the usa
Discussion in 'General RVing' started by H2H1, Feb 26, 2009.
  1. H2H1
    OK I have lost my mind, :( I have deleted the states travel map under my name, can anyone direct me on how to get it back. Thanks
  2. Guest
    RE: map of the usa
    Now hollis ,, why did u do that ???? :laugh: Give me a few and i'll find it ,, agian :) :)
  3. H2H1
    Re: map of the usa
    well I was going to add a state I left out and poof it went away. BTW Rod on skype
  4. DL Rupper
    Re: map of the usa
    Hollis, try Visited States Map by epgSoft.
  5. H2H1
    Re: map of the usa
    thanks DL that worked. I also save the site so if I screw up again I will be able to correct it. once again thanks
  6. DL Rupper
    Re: map of the usa
    Glad it worked. :)
  7. cdude
    cdude New Member
    RE: map of the usa
    I was wondering where those maps came from. Thanks for the info.:) :)
  8. H2H1
    Re: map of the usa
    hey Charles make sure u save it to your desk top so u can get to it if u accidentally delete it when up dating the map, It sure makes things a lot easier
  9. Triple E
    Triple E Senior Member
  10. The Englishman
    The Englishman New Member
    Re: map of the usa
    get a SatNav You will get more maps than you can deal with
  11. cdude
    cdude New Member
    RE: map of the usa
    Yes Hollis I saved to hard drive and as a back-up, knowing I will probably forget where I filled it, 'My Favorites' will come through, unless I forget to remember anything about the map.:laugh:
  12. Darlin
    Darlin New Member
    Re: map of the usa
    How do I put the Canadian map on with the US?
    Darlin :cool:
  13. TexasClodhopper
    Re: map of the usa
    You would have to combine them in a photo editing program.
    However, there's only so much room in that leetle display area! :clown:
  14. Darlin
    Darlin New Member
    Re: map of the usa
    TC
    You got a point there. Did not think about it. Thanks
    Darlin :cool:
  15. SnowbirdInFlight
    Re: map of the usa
    Hey Darlin I'd be more than happy to fix one up for you. Check your PM for instructions.
    Janeen
  16. Kirk
    Re: map of the usa
    I chose not to use one of those maps because someone said that if you do and your map gets full, then you have to stop traveling?
  17. Darlin
    Darlin New Member
    Re: map of the usa
    No you don't. All you have to do is to clear all the states & start all over again.
    Darlin :cool:
  18. Guest
    Re: map of the usa
    Good point ,, Darlin ,,, and see all the sights u may have missed on the first go around :approve: :cool: :bleh: :laugh:
  19. kb0ogt
    kb0ogt New Member
    Re: map of the usa
    Thomas Jefferson did not say that. it was Gerald Ford
  20. TexasClodhopper
    Re: map of the usa
    I had always read that Jefferson said that. If you do a Google search, there must be a thousand links giving Jefferson credit for it. (Says a lot for what you get from the Internet, too.)
    However, it seems that the Jefferson Encyclopedia that is loosely connected with Jefferson's Monticello attributes the quote to Gerald Ford. They state that they, "...never found such a statement in Jefferson's writings...."
    Hey, what if Gerald Ford did say it? It's true enough and a little closer to our time.
    SOURCE: monticello.org
