Monitor issue
Discussion in 'General RVing' started by KirstieTX, Mar 16, 2006.
  1. KirstieTX
    KirstieTX New Member
    Our motor home is wired for coax tv cable, but our new LCD HDTV Monitor TV for the bedroom only has RCA (red,white,yellow cable) inputs…there’s a DVD player in the living room but I have no way to go from Coax from the wall to RCA cable in the bedroom. Should I just buy her another DVD player and run everything through there in the bedroom? DVD players do have Coax inputs and RCA outputs right?
    HELP.... :question:
  2. TexasClodhopper
    Monitor issue
    That would be one way to do it, yes, but I think you might be missing a connector on the new TV. Are you saying your new "monitor" does NOT have a tuner in it? If it has a tuner in it (has channel selection), then it must have an RF input (cable). If it truly is ONLY a "monitor", then it must have been designed just to be the display for another piece of equipment.
  3. Krazeehorse
    Krazeehorse New Member
    Monitor issue
    Sounds like a monitor to me. In other words, there is nothing in there to generate a picture so you need a dvd player or a vhs recorder with tuner if you want to watch broadcast or cable tv.
