National Rv Seabreeze
Discussion in 'Class A / Diesel Pushers' started by kaktus1, Jan 31, 2009.
  1. kaktus1
    kaktus1 New Member
    Help!
    Anyone Knows where i can find a Powersteering Returnline from Pump to Box?
    For 1994 National RV Seabreeze 34ft.
    Motor is GM 454
    THanks Guys!
  2. Darwin
    Darwin New Member
    RE: National Rv Seabreeze
    Workhorse bought the motorhome chassie from GM several years ago. You should be able to locate a workhorse repair center in your area. Two other options, I had a 1988 Chevrolet MH and some of the parts for the Chevy delivery van are the same. Some auto parts houses can make hose. If you try this route take the old hose to them, they may be able to replace the hose using your fittings.
  3. C Nash
    Re: National Rv Seabreeze
    Any GM dealer should be able to order you one but I would do as Darwin sugested and take the hose to a place that will make one up for you.
  4. C Nash
    wolfgang, forgot to say WELCOME to the forum. Hope you hang around.
