need help w/allison tranny
Discussion in 'Class A / Diesel Pushers' started by Bdean, Dec 23, 2007.
  1. Bdean
    Bdean New Member
    Had the starting batteries replaced and when they did it, one of the batteries arced. Now when I try to start the engine, the tranny indicator is not lit showing "N". The info center says "PARK SET IN GEAR". Are there any fuses on the transmission that might have been blown? All of the repair locations I chacked with are closed until after the holiday. Any help would be greatly appreciated. :( :( :(
  2. Bush70
    Bush70 New Member
    Re: need help w/allison tranny
    You didn't give much in as to the year and such but there is a fuse right at the battery on some. It is in a fuse holder usualy connect at the positive termenal. Hopefully it is only a fuse and not something more serious. If you don't find a fuse there check all the fuses with a test light. Good luck
