Need help with Onan Genset
Discussion in 'Talkback' started by cougarkid, Jun 23, 2007.
  1. cougarkid
    cougarkid Senior Member
    Hi All,
    New to the forum, new to RVing, old hat at fixing/rebuilding things.
    Plan to post our starting off story soon. (1989 32' Georgie Boy Custum Cruiser)
    I have a 1989 Onan model 6.5NHEFA26100E genset.
    It was burning a bit of oil so I tore it down, honed the glaze off the cylinders and replaced the rings.
    Now I need torque specs for the piston rods and the heads. As usual it is after 5:00 and no one is open to call (and tomorrow is Sunday).
    Hope someone can help.
    Thanks in advance,
    Mike and Carla :)
  2. cougarkid
    Re: Need help with Onan Genset
    Got my answers by searching several different forums.
    Not sure which one I found it on, but here is what I got.
    Connecting Rod 12-14 ft lbs
    Head Bolts 16-18 ft lbs
    Oil Base 18-23
    Rear Bearing 15-27 ft lbs
    Gear Cover 8-10 ft lbs
    Starter 19-21 ft lbs
    Hope these will help others, too.
    Engine/generator is back together. Fired right up and purrs like a kitten.
    Now all I need to do is get the mixture set correctly.
    Mike and Carla :)
