Hopefully I found a place to seek assistance with this RV ownership and maintenance thing. I'll start in order of importance... I have a '96 London Aire 40' Cummins, and have a power issue (among other things). New problem, the "in use" button (opposite of "store) won't power up the coach. I assume it is the cause because the other issue is it won't buildup more than about 30 pounds air pressure. I can't even release the brakes to take it to get repaired. I think the air building but bleeding off what I assume is the dryer. I guess that it takes power to operate and the power is the root cause. Anybody experience something like this?
Sylenoid in the power cord compartment? Switch above the door (use/store switch)? Any info appreciated. Thanks -
