Newbie
Discussion in 'Full Timing' started by BL Bungalow, Nov 2, 2015.
  1. BL Bungalow
    BL Bungalow Junior Member
    Want to take Presidential 5th wheel to Erie to full time
    Chances of survival thru winter?
    Advice ?
    Newbie with heart and not afraid of hard work...
  2. LEN
    LEN Senior Member
    Better get it there soon so you can do the skirting and heated areas for the winter. It will take a lot of heat and there will most likely be some discomfort.
  3. BL Bungalow
    That is a very honest assessment .
    Are there resources for the products and methods used to do this ?
    Can anyone recommend a full time RV park near Erie
  4. LEN
    LEN Senior Member
    Any moble home company or contractor or if you are a do it yourself type of person can put the skirting around the RV. Just use some 2" insulation board as well are the outer cover material. Then heated dump hose and heated water connection. I would use electric heaters or if it has an electric fireplace as a primary and would get an extend a stay propane hookup for longer furnace run without a fill. Also thing like insulating the window area's while not looking all that good holds in a lot of heat. Another thing many use is a wave propane heater, the install and cost can mean the difference between comfort and cold. I stayed in a 5vr for a week in20 degree weather last year and was comfy. And it was not the quallity of the unit you have.
