Noisy Heater
Discussion in 'RV Tips & Tricks' started by ianf66, Oct 18, 2006.
  1. ianf66
    ianf66 New Member
    Hi all,
    Ive got a R Vision Condor 1330 (2000) when the gas heater is in use it seems to be a little on the noisy side, is this normal and if so is there any tips to make its less noisy? We have an electric heater that we are using at the moment but obviously this does not heat the whole RV.
    Thanks in advance for your replys :)
    Ian
  2. Kirk
    Re: Noisy Heater
    If what you mean is the noise of the blower, then it is normal. It is because the small 12V blower must turn very fast to move sufficient air to heat the RV and supply combustion air to the fire-box. The same motor turns two blowers and they are a bit on the noisy side.
