Norcold reset info needed
Discussion in 'RV Tips & Tricks' started by proflow, Nov 26, 2006.
  1. proflow
    proflow New Member
    Hi there, I have a Norcold N81X fridge that needs the board reset. Anyone know the dealer procedure for this ? Thanks in advance---Proflow
  2. Grandview Trailer Sa
    Re: Norcold reset info needed
    I know the process for a N810, but not "X". I can check the book I have for your model.
  3. proflow
    proflow New Member
    Thanks, its actually N811RT. I havnt had any luck searching that though. Any help would be great ! Thanks--Proflow
  4. Grandview Trailer Sa
    You have a 8 cu ft. refer. I am assuming you are getting the 5 flashs of lights inside on the front panel.
    If it it fairly new refer., remove the cover off the circuit board. You will see a 16 pin connector. You will have to replace the wires removed to get the cover off. Go inside and turn the refer on gas. You will see the lights flashing. Go back to the panel outside.
    On the top row, left, there is a wire in the far left pin location. The one just right to it is empty. You will have to make a jump wire out of about 12 gauge wire 8" long. Strip each end about a 1/2". Stick one in into the empty slot next to far left top. Ground the other end to any ground, the wiring ground, the LP copper will even work. Hold this for 45 seconds.
    While you hold the wire to ground, you will hear the refer click and eventually fire on gas. You are reset.
  5. proflow
    proflow New Member
    RE: Norcold reset info needed
    I wish I had that board, mines different. It has 6 pins upper left & 10 on the bottom. Still looking, thanks though ! Proflow
  6. Kirk
    proflow
    If you send me a pm I will send my email and I can send you a copy of the service manual for it in .pdf format.
  7. proflow
    proflow New Member
    Kirk, did that pm go through ? Thanks again---Proflow
  8. s.harrington
    Go to www.bryantrv.com and download the complete book on your fridge.
  9. Grandview Trailer Sa
    Sorry, but the book I have does not show the 6 pin connector procedure. Hopefully the manuals referenced will help.
  10. proflow
    proflow New Member
    Still no luck yet, but thanks for trying !---Proflow
