onan 5000 no power
Discussion in 'Class A / Diesel Pushers' started by rewists, May 25, 2008.
  1. rewists
    rewists New Member
    My generator starts and runs fine but does not produce power. i tested with volt meter at the electrical box at the generator but no juice . Any Help would be most appreciated
  2. LUeno
    LUeno New Member
    Re: onan 5000 no power
    I had a similar problem with my previous coaches Generac generator. What I found to be the problem with my generator was the brushes. I my situation one of the brushes was held in the open position (Up) by the bracket that held the 2 brushes. The brushes cost me about $15.00 plus $80.00 labor to fix..
    Before finding this problem I was told so many things, I am too embarrassed to tell you my story and how much it cost me before I met a service tech who was servicing one of the Gensets at the construction site I am presently securing. He figured out the problem within a half hour.
    I hope this helps, if there isn't any power coming from the generator check the simple areas such as the breakers at the genertor first.
  3. TexasClodhopper
    Well, Lance, you're one of us now! Learnin' the hard way! (expensive way, anyway.) :clown:
    Welcome to the forum to both of you!
