Onan Generator
turbogrampa
:question: Last nite my onan LP gen set worked perfectly. I watched the news then shut it down.
Tonite I started it and it ran for ten min, or so and never started generating.I checked at the junction box just off the gen. and no power!
What could have happened?(Both cir. breakers are on) :8ball:
Re: Onan Generator
Something broke?
What make and model of genset is it? That would go a long way to helping with some advice.
turbogrampa
Re: Onan Generator
:) Hi Kirk,
It's an Onan Marquis 6.5 Kw LP Built in 96 or 97 in a 1998 Holiday Rambler DP.
I checked both breakers and the control fuse.All GOOD.
Checked the voltage on all legs and NO voltage.
Motor runs fine but the generator will not kick in.This model doe's NOT have the large transformer as on the older models.By the way Mod.No. NHE but no Ver. No. at the End.
Any help will be greatly appericated.
Turbogrampa
!998 Holiday Rambler ,5.9L Cummins
Flat towing Acura TL
1996 Dodge Ram 5.9L 288K and running like a Deere.
