Onan Marquis Gold 5500 problem
Discussion in 'Class A / Diesel Pushers' started by stingjra, Dec 13, 2006.
  1. stingjra
    stingjra New Member
    I just bought a 2002 Fleetwood and the generator will not stay running. I have remove carb. disassemble and clean, complete service oil/fuel filter. The fuel tank is 1/2 full. When the starter is turning over it will run smooth but when I release the start button the fuel and the ignition shuts off. I am thinking it is a electronic relay or something but trying to see if any one has answers or a common problem. Model is 5.5 HGJAB-901A Thanks
  2. C Nash
    Re: Onan Marquis Gold 5500 problem
    Does it do the same from the cockpit and gen compartment start switch?
  3. s.harrington
    Could be a couple of problems. The board could be bad, the regulator could be bad, the brushes or rings could be dirty, or if equipped with a low oil switch oil could be low or switch could be bad. I am assuming it has 150 hours or less on the gen set. If it has a lot of hours the brushes could be bad.
  4. mlb711
    mlb711 New Member
    RE: Onan Marquis Gold 5500 problem
    Had same exact problem as you describe on my 2002 Fleetwood. They had to replace control board.
