Overheating
Domingo
I continue to have a problem with overheating since I purchased my RV.The previous owner may have had the same problem since I found several bottles of antifreez. I asked him he denied it.
I have had the radiator flushed, changed termostat,tersted fan clutch, water pump is working fine andhad the radiator taken out and dismentaled and cleaned.Hose and belts are in good working order.I continue to have the problem. Here is what happens. I drive 55 mph temperature is fine however once I increase speedtempeture starts to crip up. Temperature drops to normal asI decrease speed back to 55.Alsotemperaturerises as I climb hills. It overheats as well if I use the dash air. I am not towing. I seem to lack power as well to climb any hills. It does not overheat and can drive at any speed during cool weather however it still overheats as I climb hills specially on a long drive. Any ideas on what to do next.
The rv is a 2000 Holiday Rambler Endeavor class A 36' ford V10 gas.
TexasClodhopper
Re: Overheating
Domingo, when you say "overheating" what do you mean? How are you determining that the engine is overheated?
You didn't mention your engine fan. How is that looking?
Do you think you are overweight? Oh, I mean your MH! :clown:
Re: Overheating
Domingo Do a search google as I just read a thing on your rig in another forum. As I remember it is a issue that is well known and I think there were things to do to get it working right. If the your rig pukes antifreeze, that is exactly what they were talking about.
Domingo
RE: Overheating
The tempeture gages go way up almost redlining it. there where several times where I had to pull over and let it rest a while.
Tex yes I am a little over weight and over heated when this happens.
It puked anti freez maybe once.Can you tell me which forum you whent so I can look at it as well. I have been googelinng as well. I found that I may need to check the timing and possibly the transmission.I will also locate a mechanic that can look at those things. Would love some more ideas as well
Re: Overheating
I would have the engine checked for possible head gasket problems. Timing could also cause this. How many miles are on the MH? Have seen rare cases of water pump causing this. Is your radiator cap sealing as it should?
Domingo
RE: Overheating
I am not sure if radiator cap sealing well but will check that. I sure hope is not a blown head gasket. I have been all over that motor, there is no oil leak and everything apears fine, but that's just me looking at it. The MH has 40,000 miles. What ever it is, I have to find the problem before it gets worse. I am planning a long trip in August one of the hottest months in Texas.My next goal is to find a good mechanic in the area.
Re: Overheating
Also check for exhaust backpressure. You could have a cattalitic converter stopping up.
G
Guest
Guest
RE: Overheating
when u do ,, make sure they can do a hydrocarbon test ,,, that wil determine if in fact u have a head gasket or other problem ,, i know u said u don;t see any coolant ,, but it could be leaking into the cumbustion chambers ,, and a hydrocarbon test ,, will find that out ,,, it detects as the word says hrydrocarbons ,, and if u have a leaky head gasket ,, it pushes the exhaust gases and such into the coolant ,, but i have feeling u have flow problem ,, since it only happens when going faster and uphills ,, but have the cap tested ,, there are many things that can cause this ,, it might be a process of elemination ,, but have the hydro test done first ,, that will tell all :approve:
It might be as simple as a bad sending unit ,, and u are not really overheating ,, but nash made a good point ,, about the converter
:approve:
Re: Overheating
Another thought, does the ck engine light ever come on? A lean combustion condition will cause overheating. Be sure and get your load limit in specs.
Pillaz
RE: Overheating
I am having the same problem again this year. I am wondering how you made out? I have a 1990 chevy 454. It seems to run fine. Looses no oil or coolant and does not puke coolant. If it were a head gasket or warping would it not smoke and loose coolant?
Re: Overheating
You may or may not see smoke. What is the temp? If it's running hot you should be loosing some coolent especially when shuting the engine down. Do you ever hear a gurgling sound after cutting off the engine? The 454s tend to run on the hot side. 210 is pretty common on hot days and pulling hills. Personally I think the chevys have a radiator that is to small JMO. I have the v10 ford and it never gets halfway on the guage even on hills and hot days.
Pillaz
Re: Overheating
I don't hear any gurgling and she doesnt smoke. RV does not dump coolant. However by the time I come to a stop the temp gage is back to normal. I had this problem at the beginning of last year. I changed the fan clutch, Thermostat and flushed the Radiator. Flushing the radiator seemed to help. Since then it has run warmer than it used to but not near the danger zone. I have taken three trips this year and it has been running the same as last yr. On my last trip on the way out the weather was in the 80's and I had no problem. The return trip, which we were lighter and the weather was in the 70's it got too hot climbing a couple of hills and I had to stop. Again by the time I come to a stop the temp level is normal. My son joined the Marines and is graduating boot camp in two weeks which means we need to go to South Carolina and I am concerned that driving in high heat will really be a problem.
By the way since I have owned this MH 4yrs It has alway had a leak in the exhaust manifold over one of the cylinders. It does not seem to be getting any worse and was like that for two years before I had a heat problem. I am at a loss.
Thank you guys for all of your help.
Re: Overheating
If it does not have a separate trans cooler I would add one. They are not too much money and an EZ install and will take the trans heat off the engine cooling. Also take a good look at the return radiator hose to make sure it is not squashing as the water pump is pulling the water from the radiator. As it gets hotter and softer they restrict flow at times doing what you describe. The minute you slow the demand is down and the flow is increased.
Pillaz
RE: Overheating
MH already has a trans cooler. I am thinking about taking the thermostat completely out to improve coolant flow. Has anyone tried this??
Thanks for everyone's imput
I will check the hoses, Thanks
Re: Overheating
One problem with removing the thermostst is the water could flow to fast through the radiator on long trips and actually run hotter. Not enough time in the radiator for proper cooling. Not likely to happen bit possible. I think I would install a manual guage to verify if it truly is hot. 210 on the 454 is not exsesive. You said flushing seemed to help so it might be time for a removal and a true rod out of the radiator.
Pillaz
RE: Overheating
Here is the latest. I flushed the Radiator again and Changed the spark plugs. The plugs seemed fine but now they are new. I took it for a test run but it was unloaded and ran fine and the temp gage read normal. Has anyone heard from Domingo? I am curious to see how he made out with his MH.
Well I leave for Paris Island on the 4th. With anyluck I will make it. It would be nice to make it hack as well. I am thinking that I may have to drive 55mph on I95 which is a little scary. I will let you know when I get back how I made out. :question:
Re: Overheating
If the MH has a good many miles 78000k up or an older model I think removing the radiator and having it roded out is best. Flushing will not remove all the sludge that has settled in the bottom flues. JMO
Shadow
Re: Overheating
Think Chelse right, I had a chevy pickup with the 454 in it with a lot of miles. Starting having heating problems. Replaced hose's, plugs, thermostats, flushed the radiator, new cluch fan. No help. I ended up just buying a new radiator. Problem solved.... Didn't rod it out because of the age. And it had been patched a couple of times.
G
Guest
Guest
Re: Overheating
well it is hard to find anyone that does the rodding out of rads anymore ,, and if u look at the cost of a new one verses the labor of rodding one out ,, it is almost the same ,, well atleast here ,, we have one rad shop that use to do the rodding ,, but now all they want to do is sell u a new one ,, and at more cost then u can go buy one u'r self :eek: :angry:
Pillaz
RE: Overheating
The MH has 57k on it.. It may in fact be the Radiator. It may be the temp Censor. Unfortunately I do not have time to change the Radiator before I leave. I picked up a new temp sensor and will try to replace it this weekend if I have time. I don't think it is the sensor tho because most of the time the temp gage reads normal. With any luck I will not have any problems in the next 2200 miles. Maybe there is someone between central New York and South Carolina that will sell me a good cheep deisel pusher.I think after this year I will start looking at Deisels. The MH has been a good old girl for the last four years but maybe its time for an upgrade. I am looking forward to seeing my new Marine
