parts for duo-therm
parts for duo-therm
Igniter boards can be switched and probably thermostats and switches, as long as they operate at the same temperatures and will fit into the space. On an orifice, the key is that it must fit the threads and it needs the exact same size of opening. If it does and is still made of the same material there should be no reason it won't work.
lucy1946
parts for duo-therm
KIRK, DO YOU HAVE ANY SUGGESTIONS AS TO WHAT BRANDS TO LOOK FOR TO FIX THE FURNACE? MY DAUGHTER AND I BOUGHT THIS 1983 TIOGA MOTORHOME FOR THE GRAND DAUGHTERS AND US. THE ONLY THING THAT DOES NOT WORK IS THE FURNACE. SOMETIME IT GET CCCOLD! IN MICHIGAN.
THANKS LUCY12
Grandview Trailer Sa
parts for duo-therm
Have you tried to contact Duo Therm? It is a Dometic product and I can see if the part is still available. I would need model and serial number.
lucy1946
parts for duo-therm
THE MODEL # IS 65930-064 AND THE SERIAL # I L-288850. WOULD HAVE THE CONTACT NUMBER FOR DUO THERM? THANKS FOR THE HELP. LUCY12!
