Plumbing question
Discussion in 'Talkback' started by Clark, Jul 27, 2011.
  1. Clark
    Clark New Member
    I have a 91 country coach Savanah. The three lower drain valves have some annoying leaks that come out thru the tubes under the coach when I hook up the water. I have taken out the valves and cleaned and replaced, but still have dripping under the coach. Does anybody carry these valves, or do I have to replace with a different kind.
  2. cougarkid
    cougarkid Senior Member
    Re: Plumbing question
    My 89 Georgie Boy had the same issue. Cleaning did NO good, either.
    The valves are available. Take one to a local hardware storre and match it up.
    I took the guts out of the valves and found a cap that would screw on it it's place.
    No more leaks and the cap will still come off to drain.
    Mike
  3. Clark
    Clark New Member
    Thanks, I will give that a try.
    Clark
