Poor Water Pressure
ssatexn
I am trying to get more water pressure. Right now it is pretty much a dribble. Any suggestions on how to clear lines, check for bad seals etc. that would help boost the pressure?
Grandview Trailer Sa
Re: Poor Water Pressure
Have you checked the strainers onthe faucets? Had the same thing today at kitchen faucet...Found lots of debris. Also, are you on city water or using the pump?
utmtman
Also there is a filter on the pump if you are using your tank water so check that filter. Also is there a filter on your incoming system if using city water???
Well thanks Lee for that tip. I never knew there was a filter on your pump from the water tank. I will look at mine and clean if needs. I don't have a problem with water pressure. But that is a good tip. Thanks
