Power Converter
Discussion in 'Talkback' started by tevz32, Aug 18, 2007.
  1. tevz32
    tevz32 New Member
    Just bought a used Palamino truck camper (1996). It has a Magnetek 6606 converter. Is this also a battery charger? If not, how can I keep the battery charged while traveling?
  2. hertig
    Re: Power Converter
    The converter runs off the 120v power line, so if it charges, it only charges when you are plugged in.
    Most converters do charge the batteries, although they are not very good chargers.
    Other options is to run a charge line from your truck system to the battery, or install a battery charger which works when you plug in.
