Propane fridge
Discussion in 'Talkback' started by Westhawk, May 26, 2005.
  1. Westhawk
    Westhawk New Member
    Just bought a 77' Edson Buffalo camper trailer (17' - 1700 lbs) and am very new to RVing...
    How does the fridge work? I found a panel outside the camper that reveals the back of the fridge; there is a copper line with a ball valve, then a manifold with a red button, then what appears to be a port where matches had been inserted. What do I do, look for, set it at, shut it down, etc.?
    Can I run this on my A/C supply?
    Any help is appreciated...
    P.S. Had a near death experience while towing and passing a semi... MAJOR SWAY! Whats up?
  2. Poppa
    Poppa Member
    Propane fridge
    Well with a little help from you we can help.
    Need the make and model on the frig. Normally you can get hold of the mfg and get an instruction book.
    As to the major sway, what kind of vehicle are you towing with? Do you have any idea what the tonque weight is? (Does the back of your vehicle squat very much)
    Bad shocks on the tow vwhicle will contribute greatly to swaying. One thing is when it starts to sway, Do not try and correct it with the steering, that just makes it worse, back off the gas and hold the wheel straight of course unless your headed to a ditch.
  3. Kirk
    Propane fridge
    On a 1977 RV refrigerator, it probably is two way, and could be three way. Inside on the front of the refrigerator there should be a selector to choose between the different power sources. That is where you start. Locate the inside controls and see what you have. If there is no selector at all, then it would appear that you have a propane only refrigerator, but that is very unlikely. While you are there, look to see what brand it is, and if you visit the website of the manufacturer, you can likely down-load directions or a manual. If you can't get the manual for one that old, you can do come tests.
    First, since it is an older refrigerator, use a shop vacume to clean the area where you see that has been used for lighting. Be sure that you get it as clean as possible. Next, make sure that you have propane in the tanks and I would also use soapy water to check all connections for leaks. Once that is done and there are no leaks, you are ready to try and light it.
    Open the little window where you light it and get one of the butane lighters for a gas grill, rather than a match. Look at the control knob on the valve as it may have positions of off, pilot, and run. Make sure that the ball valve is open. Set the knob to pilot and insert the lighted butane lighter into the hole. Now press the red button down and hold it, watching the inside for a flame. You should see it light and it may take a minute or two since there is probably air in the line. Once lighted, remove the lighter while holding the red button down. You will need to hold that button for a minute or two as there is a safety thermal couple that must heat up to make the unit operate. Once it will stay lighted, look for some type of run setting to change the control to, it is has one. There should also be a temperature control that can be adjusted.
    Keep in mind that since your refrigerator is nearly 30 years old, if original, it may not work as they do have a limited lifetime. If it does not operate it would likely not be worth spending a great deal to repair it. New RV refrigerators have electric ingnters and automatic power selection to change from propane to electric power when available.
  4. Westhawk
    Westhawk New Member
    Propane fridge
    Thanks for the replys gentlemen!
    Tow vehicle is an '02 Ford F250 Super Duty in mint shape, 5000 lb. hitch package (I tow double and triple axle flat decks loaded with golf cars with no problem). In won't be towing this trailer much anyway, and will certainly not pass another semi anytime soon! Just wanted the info so as to not put myself in that position again... very scary!!
    As for the fridge, I am going out to the site tonight, and will follow your advice...
    Thanks again guys!
    Mike from Winnipeg, CANADA
  5. Krazeehorse
    Krazeehorse New Member
    Propane fridge
    check the tire pressure in the trailer tires...sounds like they could use a little more air.
  6. Westhawk
    Westhawk New Member
    Propane fridge
    There are no selector switches inside the fridge, and the only directions I could find were propane related. I guess the fridge is propane only. Tire pressure is 55 p.s.i. (max. rating on new tires).
  7. Kirk
    Propane fridge
    What make and model refrigerator is it? There just might be someone out there who has the same one.
