ques on wheel barrings
Sanesensne
anyone, I have a 99 dodge stratus, wheel barring is gone. What causes this and why so soon. Anyone know if would be under original waranty? Please let me know. Send replys to:
Sanesense@aol.com
Carolyn A.Plumley
Carolyn,
We need a little more information. Did you buy it new? Front or rear bearing and how many miles are on your Stratus. You could call your local Dodge dealer and ask but, don't just accept no if it is low milage. Ask them what caused this. May be a common problem.
Stratus had a problem in 98 with a low frequency rumble or gear type noise coming from the front of vehicle between 50 & 75 mph. Noise was not throttle sensitive.
Diagnosis: Verify sympton/condition is present, inspect front hub/bearing assembly build code datelocated on the outer edge of the hub nut cavity. If the build date is from 6/11/97 through 8/12/97 there is a recall. Yours could fall in this even though it's a 99. If build date did not fall in this range futher diagnosis is required. Good luck
Chelse L. Nash
fulltimer03@yahoo.com
Edited by - c nash on Oct 03 2001 11:31:59 AM
