Re: QUESTION ON ONAN GEN
Um, kinda hard to understand what you're saying, but I *think* you're saying that when you run the generator only the front air runs but nothing else? When you plug into shore power it all works? There are two circuit breakers on the generator, you might want to check those. Also, check any ground fault interrupters (probably located in the bathroom) and make sure that's not tripped. If all of that's okay, I'd check the transfer switch. If it's a 30 amp RV, probably only one AC will run at a time when plugged into shore power unless you have some sort of powersaver onboard.
