R-Vision Condor Slide question
Discussion in 'Talkback' started by nschramm, Jan 6, 2008.
  1. nschramm
    nschramm New Member
    Anyone know how to manually get the slide in & out on a Class C 31 footer? And any ideas on why the slide won't go in & out? When I push the button, I don't even hear anything. I checked fuses & tried a couple of reset buttons underneath the stairs but nothing has worked.
    Thanks -
    Nadine
  2. Guest
    RE: R-Vision Condor Slide question
    If u look under the slide (outside ) there should be a jack or a crank that u can pull the slide in ,, i would also ck in some of u'r outside compartments ,, sometimes they put fuses and such for the sldies in them ,,,, JMO
    Welcome to the forum :) :)
  3. TexasClodhopper
    Re: R-Vision Condor Slide question
    Mine has two square 'covers' and a long crank handle in the bay. You take those covers off, put the crank in there, and sweat. Then you do it a little on the other side. Then back to this side. And so on and so on ...
    Then when you get home, you start looking around for the problem.
    My Winnie's are run by electric motors and gears. Some are hydraulic, but probably not on a Class C.
  4. nschramm
    nschramm New Member
    I did check under the slide & in the compartments, but I didn't see anything that looked like a crank. But I am not exactly mechanically-inclined so maybe I missed it.
  5. Guest
    have u cked the owners manual ,, if so there should be a page in there about the slides ,, and what to do if the power fails ,, it should point u to a manual emergency setup ,,,
    If it doesn't i would put a call into the local rv shop ,, as for me ,, all the slides i have seen have manual cranks or jacks that can return the slide to a closed position ,,,, JMO :)
    If u give me the year and make of u'r rv ,, i can look it up and get the factory manual on all the options ,, and maybe this will help :approve: :)
  6. hertig
    On mine, there is a lever on the motor you flip to disengage the motor, then use a wrench to rotate the shaft to bring it in manually.
  7. nschramm
    nschramm New Member
    The owners manual just said to ask the dealer, which is in FL & I'm now in TX (& they weren't very good anyway). It's an R-Vision Condor Class C 2003, 31 foot.
  8. Guest
    I think that should be a dealer where u are at that could answer u'r question ,, but i would also ck if there is a local mobile rv repair service that might have seen this problem ,, i myself have only delt with a few slides and all were blown fuses and one was a critter chewed wiring harness ,, but please let us know how it turns out ;) :) :) :approve:
