re oil replacement in rear end
Discussion in 'RV Tips & Tricks' started by kojak, Dec 27, 2008.
  1. kojak
    kojak New Member
    Hi Rver's, i have a rear end pinion plate leak and have drained the oil to repair, and with out a manual i dont know what grade oil should go back, does anyone know if it could be 80/90 or 85/140 grade it is a 1987 Monaco 36ft single rear axle daul wheels, I asume it is a LSD as when all wheels are of the ground both turn the same way. many Thanks Kojak
  2. Guest
    RE: re oil replacement in rear end
    Hang on ,, i will get u the specs on the rearend fluid
  3. Guest
    I show to use the 85/140 ,, with a friction additive ,, u can get this at any parts store ,, it's called transX ,, it's a fristion modifier ,, and it's accepted by all manf. of LTD rear ends ... hope this helps ,, I would go with a synthetic ,, it does not say to use that ,, but i would :approve: ;)
  4. kojak
    kojak New Member
    Re: re oil replacement in rear end
    Hello 730, thank's for quick help i will get some synthetic in what you suggest, its hard with these older rvs when we cant get a manual, thanks again Kojack
  5. H2H1
    once again 730 saves the day for a Rv'ers
  6. Guest
    not me ,, the gear lube did ;) :laugh: :laugh: ,, i am just trying to help out ,, without an ADVERTISEMENT ,,, oops did i say that :eek: :eek: :evil:
  7. H2H1
    yeah right, I see you advertisement in you signature. :laugh: :laugh:
  8. Guest
    well i do need 100 more post to get to the 2000 mark ,, hmmmmmmm ,, need to go after the hitch guy more ,, runs the post count up :laugh: :laugh: :laugh: :evil:
  9. H2H1
    do it one word at a time :laugh:
  10. H2H1
    go to the chat line
  11. brodavid
    brodavid Senior Member
    730 go for it
