Rear Sway Bar on Roadtrek
Discussion in 'Class B Motorhomes' started by larrylwill, May 13, 2006.
  1. larrylwill
    larrylwill New Member
    In 2004 I installed Bilstien shocks and a Helwig rear sway bar to my 1993 Roadtrek 22ft. Last week a found that the sway bar lost the 2 bolts that attached one side to the under carriage. I cant find the installation instructions and for the life of me I cant figure out how I got the bolts inside the box frame channel. There is no opening. Also looking at it I would think it would work better if the end of the outside bars faced backward instead of foreword. Can anyone help?
    thanks
  2. suebea05
    suebea05 New Member
  3. ggtreker
    ggtreker New Member
    RE: Rear Sway Bar on Roadtrek
    If you havent got an answer, this may help:
    I think there's a rectangular hole close to the back of each side of the frame where you can fish the bolts thru. If you have the optional trunk, you probably wont be able to see them. I've scavanged a class 3 hitch and the only way to use it is to take out the trunk , fish the mounting bolts thru that opening into the predrilled holes for the hitch mount. Then redo the trunk without the sides that overlap the frame. Hope this may help. :)
