Rear tires on TT wearing on the inside
Discussion in 'Talkback' started by circpro, Jul 3, 2005.
  1. circpro
    circpro New Member
    I have a 2003 Keystone 26 ft dual axle. I noticed both rear tires are wearing badly on the inside. Is there anyway to fix this short of a new axle? (I'm assuming somehow it's bent)
  2. C Nash
    Have you weighed the Keystone? Could be an overloaded condition causing the wear. If the axle is bent it could be bent back but,problem might return. 2003 might be covered under warrenty if it was not caused by overload or hitting something. If you hit something insurance might cover it.Contact Keystone and see if there have been any problems with this but ,don't hold your breath that they will admit it. Axle could have been installed wrong (bottom side up). A good spring shop should be able to repair this or a come-a-long and some tie downs with a tape measure might cure the problem but, new axle might be simpler.
  3. C Nash
    How many miles have you towed the keystone?
  4. circpro
    circpro New Member
    I bought it used last year, so I am not totally sure. The spare has the same wear. I personally put less than 1000 miles on it in the last year.
  5. ruffian
    ruffian New Member
    Watch your tire pressure.
  6. Krazeehorse
    Krazeehorse New Member
    If the tires aren't worn out yet take them to a tire shop and have them reversed on the rims and rebalanced. This way the deep tread will be on the inside where it is wearing. Shouldn't cost too much...maybe $20. This doesn't solve the problem but it will save you a little money.
