Refrigerator Help
Discussion in 'Towables' started by bernie22, Apr 1, 2007.
  1. bernie22
    bernie22 New Member
    We own a 1983 Jayco Popup J Series. The man I bought it from says everything works including the refrigerator, but I can't figure out how to make it work. It runs off gas, but I can't find the pilot light. Any info would be appreciated.
  2. DL Rupper
    Re: Refrigerator Help
    See if you have an on/off switch for the fridge. It probably runs off of a 12 V electric igniter. Turn on your propane and make sure propane is in the line (ignite your stove and then turn it off). Then see if you can set the temp on the fridge. Check the back of the fridge to see if you have a gas flame.
    Being that we are talking about a 1983 I'm not sure if this will help.
  3. AVTraveler
    AVTraveler New Member
    I would think it might be a burned out 12v Fuse. Check your fuse panel.
