Refrigerators
Old Forum Post
[Tony] Does anyone know why there are 2 way and 3 way fridges? I currently have a 2way and I don&#039t think it&#039s safe to drive with the propane on. Please advise. Thank you.
Old Forum Post
Refrigerators
[Gary B] Hi Tony, 2 way refers cost less, are less compilcated, then 3 way refers, and many folks feel it is perfectly safe to use LP. The 12 VDC operation draws a lot of amps from the electrical system (typically 15 amps) if your tow vehicle is not equipped with a heavy duty alternator, it may not be able to keep up. If you stop for a while to do some sight seeing, etc. and forget to switch to LP it will drain the battery very quickly. Happy Trails GB
