replacing toilet
Discussion in 'General RVing' started by kiddsareus, Sep 27, 2006.
  1. kiddsareus
    kiddsareus New Member
    :dead: Just bought a used Rv and just took a good look in the toilet :dead: . Gonna have to replace it and I know nothing about toilets. Any advice on what kind I should get. My RV is a 1989 36 foot Class A Georgie Boy. We are actually totally redoing the inside so now would be the time. Thanks for any and all advice!
  2. s.harrington
    Re: replacing toilet
    Sealand makes the best but its $300.00 . A good Thetford will run you half that but is plastic. Stay away from anything cheaper. I have never had good luck with those $90.00 toilets. :)
  3. kiddsareus
    Thanks alot for your help. I know it sounds like a silly question - you should be able to just go out and buy a toilet - but I've heard different terms like "high rise" and don't even know what that really means. I'll stay away from the $90 tiolets. Thanks!
  4. DL Rupper
    RE: replacing toilet
    High rise is for when you have trouble getting on and off the pot. :clown:
  5. kiddsareus
    LOL - OK thanks - clears that one up! :laugh:
    Do I want one with a sprayer - what are the advantages?
  6. hertig
    The sprayer helps you get stuff down that doesn't want to go. As such, it is useful. However, I wonder if toilets that don't have problems which cause you to need a sprayer might be better. Mine, for instance, attracts toilet paper as if it were iron foil and the toilet bowl was magnetized. Even the sprayer has a hard time getting it to let go.
