Class B : Roadtrek 210 Popular, 2010.
I have a problem with the monitor panel.
Someday found that the battery LED light on monitor panel is turned on and it never goes off even I switch it to off position.
When I disconnect AUX battery cable, then it goes off, but when I re-connect it, the LED light turns on again and never goes off.
In this case, what should I check ?
Appreciate your advise...
thanks.
thanks.
