Re: RV Identification Labels '83 travelcraft
I'm not quite sure what you are looking for? There will be a VIN and also a RV manufacturers serial number. The VIN location will depend upon what chassis you have but a manual such as Chilton's should be able to help you there. In most cases there are also data plates located on the inside of the RV, one usually near the drivers position inside of the RV or on the door frame. Usually there will be another data listing that is mounted on the inside of one of the storage cabinets, and that could be anywhere but it is usually on the inside of one of the doors.
