RVBathtub
Discussion in 'Full Timing' started by naturesher, May 19, 2005.
  1. naturesher
    naturesher New Member
    Hi again,
    A couple of months ago I noticed that when I stood in a certain spot in the shower, in floor of the shower made a crackle sound. I checked to see if there was an actual crack in the floor of the tub, and there was not one. Now recently, it crackles in more places, and I am worried it is falling through or something. Does anyone know what this is, and if I need to remove the whole tub for some reason? Thank you so much!
    Sher
  2. Kirk
    RVBathtub
    There should be an access panel that will make it possible to see under the tub at some location. It sounds to me as though the support for the bottom of the tub has moved, or somehow failed. I would start by checking under the tub to see what is there. Mine has blocking under the tub to support the floor in several places.
    Good luck!
