Shower door hits on bottom
Discussion in 'RV Tips & Tricks' started by gagoguen, Apr 26, 2017.
  1. gagoguen
    gagoguen New Member
    I have a 2013 Thor Daybreak 32HD, the shower door is hitting on the bottom outer edge, not the hinge side, it looks square except for the bottom. I don't see any way to adjust the door. I have replace the lower seal, and it is torn up again. You have to pull up on the door to open it. It is a glass door between 2 straight glass panels along the top of the tub. Any Ideas?
  2. C Nash
    has it always been like this? Is it possible that a water leak has warped the floor? If this is a new problem something has shifted. May have to preposition the hinghes
  3. gagoguen
    gagoguen New Member
    That's my problem. I can't find anything to adjust
  4. C Nash
    Probably has no adjustment. Something has moved so you have to figure out what. My guess would be water damage. Again, has this always been a problem? Did you buy the rv new or used. A level may help find what has shifted. Just hard to say not seeing it. Maybe a call to MFG might help
