Silver Eagle Engine Removal
Discussion in 'Talkback' started by alcusmc, Jun 9, 2006.
  1. alcusmc
    alcusmc New Member
    Has anyone removed or had removed a Ford 460 fuel injected engine from a Silver Eagle Motorhome.. ? Does it come out the top and the drivers door or do you have to remove the front cap? The engine cover has been glued and screwed to the floor.. I have removed the screws but the cover wants to break when I start to pry on it to remove it.
    Thank you for any comments.
    alcusmc
  2. Kirk
    I don't know about the motorhome that you have, but it is very common for the front axle to have to be removed in order to remove the engine from many class A motorhomes. You then drop the engine out the bottom. It might help if you were to give a year as well as make. Good luck!
