swbouton
Junior Member
I don't know what the apparatus is called at the front of the 5th wheeler that allows you to raise and drop the front. I call them the "levelers" and I need a way to simplify the use of mine.
I have trouble getting the pins in. If I extend them too far, the fuse blows. And, it usually requires me to sit in gravel or mud while I make the adjustments and move from one side to the other.
I do know that it is better to put the pins in from the inside toward the outside and that helps.
I wish I could just press a button and they would extend or retract as needed. Are there better alternatives?
Thank you.
Thank you.
