siphoning gas from gas tank
Discussion in 'Class A / Diesel Pushers' started by amodany@comcast.net, Oct 31, 2011.
  1. amodany@comcast.net
    amodany@comcast.net Junior Member
    i need to siphon gas from my tank to be able to store it safely. the neck to the tank has two 90 degree angles. i have tried a few hoses, but have been unable to reach the gas. does anyone have any suggestions? thanks
  2. akjimny
    akjimny Senior Member
    What kind of motorhome? Does it have a drain fitting on the bottom of the fuel tank? Is there any other way you can get a hose into the tank without going down the filler neck?:)
  3. LEN
    LEN Senior Member
    Please explain storing it safely. Almost MT tank is more dangerous than full(air fume mixture =explosive). Full tank = less condensation(water in gas). If for very long time total drain of tank would in the cards, at least over a year. If under a year full tank and the appropriate amount of Stabil a fuel preserver.
  4. C Nash
    I agree with Len. Why drain? Tank is better left full with correct amount af fuel stablizer. Is there a safety factor of where you are storing the MH with full tank?
  5. brodavid
    brodavid Senior Member
    mostly empty > water condensation = rust
  6. Cruzincat
    Cruzincat Member
    Never mind! I initially wrote something stupid.
