slide out motor
Discussion in 'RV Tips & Tricks' started by brewdoggy, Mar 14, 2006.
  1. brewdoggy
    brewdoggy New Member
    slide motor just quit working today, is there a reset anywhere, battery is good and i checked all fuses and breakers, is there something i am missing? thanks for any help
  2. s.harrington
    slide out motor
    Some slideouts have a protective circuit on them. It may be a relay or a fuse on a small circuit board. If its in a Monaco there is a bank of relays near the batteries that may need some maintainance. If you have a trailer or 5th wheel you need to look in a cabinet in the room with the slide out usually down low in a protected area there should be a small circuit board with a fuse on it.
    good luck finding it.
