Slideout roof leak
rwigspra
I have a 2001 28 ' Cherokee 5th wheel by Forest River. I bought is used in 2006. The living room slide leaks. It drips out from the back corner right onto the cusion and me when I sit there. I have covered it with 2 mil thick plastic drop cloth and it still leaks. I covered it with a large tarp that completely covers the slide as well as half the roof and it still leaks. What do I do?
My A/C also leaks. when I run it constantly, especially in the summer in FL. I have noticed that the back wall behind the cabinet is wet and deterioating. I have looked all over the ac unit and can't find a leek. What can I do?
Re: Slideout roof leak
Sounds like you are going to have some major repair :( If you can not locate the leak take it to a good repair shop. You can try spraying just sections at a time to try and isolate it. Probably coming from a spot away from where it shows. Ck all seems and all chaulking around pipes and vents
