Slipping Allison
Discussion in 'Class A / Diesel Pushers' started by peety1, Feb 11, 2007.
  1. peety1
    peety1 New Member
    I have a 3000(06) MH w/cat350 with 35,000 miles....for the past 15,000 on occasion it slips and races 4-500 rpms between 3rd and 4th...Allison has reset the computer for adaptive learning 5 times....it shifts fine for several hundred miles then it slips, then it goes back to normal shift...Allison replaced brain last week...did fine for 400 miles, now its slipping again probably 10-15 times during 500 mile trip...Has transynd from plant....fluid level is correct when hot by sensor and dipstick(slight foaming at very top)...any suggestions...with a very cold ambient (20degrees) temp, it hard shifts from neutral to drive on the first shift...after that its ok...Idle is at 700 during hard shift...don't know if these are related but I'm *** tired of returning to Allison just to have the same problem re-appear. The coach wt is 31,000 lbs with additional 10,000 lb tow capacity. I tow a yukon xl ( 5700 lbs).
    Thanks....
    Update...I'm in Ocala and it is now slipping from 3rd to 4th every time unless I baby the shift....Does anyone have experience with Florida Detroit Diesel-Allison. located at 224 SW 52nd Avenue. I haven't called them yet.....
