James Cann
Hi, I just finished installing solar panels on my 2003 Rexhall Aerbus. It says that I should disable the 12 volt converter while using the inverter so I don't waste the stored electricity in my batteries. I located the converter, it's behind the circuit breaker panel under the fridge. I didn't find a fuse that disables it other than the big circuit breaker that supplies the receptacles. Is this the way to disable it? If so it appears it will disable the 110v receptacles also. Thanks for your help.
Jim
Jim
