spring rubbers
Discussion in 'Talkback' started by glennis, Feb 11, 2007.
  1. glennis
    glennis New Member
    We have a 1978 21 & 1/2 ft motorhome. I would like to stiffen the back suspension up some. I am thinking about putting in some round rubber inserts into the rear coil springs,
    (saw some in Canadian tire yesterday). Does anyone think this would help and if so how many would each spring need. I can,t afford to go to the expense of pulling the springs and having them reset. I will be towing a 4ft x 8ft utility trailer behind me, loaded up to 1500lbs or probably less, tongue weight 200lbs or less. Could I put these rubbers in myself rather than taking it to a shop. If this would not work, is there any other suggestions. :laugh: always appreciated,thanks.
    Chas.O.
  2. utmtman
    utmtman Senior Member
    RE: spring rubbers
    Well I remember using them in the old days. And I put mine in myself. Usually used two per spring one across from each other. In them days we used to also put springs around the shocks to also do similar. Could buy kits in any parts store for either direction or if one wanted to do both.
  3. Poppa
    Poppa Member
    Re: spring rubbers
    The rubbers will help raise the unit but won't do anthing for actual spring rate. Suggest purchasing some heavy duty coil over shocks. They will help the spring rate as well as help out on any swaying condition
  4. Grandview Trailer Sa
    Re: spring rubbers
    Sorry, but I don't understand why you need them for a 4 x 8 trailer weighing "probably less than 1500lb."
    I would think the suspension in a 21 1/2' motorhome would be more than adequate.
  5. DL Rupper
    Re: spring rubbers
    Being a 1978, maybe the suspension is worn out?
  6. C Nash
    Re: spring rubbers
    If 200lb of tongue weight bottoms it out it's time to replace springs IMO
  7. kotr
    kotr New Member
    Re: spring rubbers
    You didn't mention what brand chassis you have but I thought most used leaf type springs in the rear suspension. If so Firestone makes air bags with up to 5000# of help for those old sagging springs.
