steering stabelizer--canp world
Discussion in 'Class A / Diesel Pushers' started by Paul & Susan, Oct 21, 2007.
  1. Paul & Susan
    Paul & Susan New Member
    We have a 96 Itasca 34' suncruiser. Steering is not bad. Howeveri wonder if
    it can improve. anyone have any experience with the subject.
  2. Kirk
    Re: steering stabelizer--canp world
    Question first, what chassis do you have? There are some things that will help but just what depends. If you have one of the P-30 chassis from GM then you may also need to adjust the air pressure in the front air bags that are inside of the coil springs. They are also well known for leaking air so you could need to replace them. Most chassis of that era can benefit from one of the many steering stabilizers and you can find differing opinions as to which is best. I suspect that in reality, the best is different for the Ford chassis than for the GM.
  3. Paul & Susan
    RE: steering stabelizer--camp world
    It is a P30 16500# chassis with air bags. I'll have to check the presure in the bags. The unit does set level. The state inspection is due soon. I was thinking that this might be the time to check into something like that.
    Paul
