suspension on bounder
Discussion in 'Talkback' started by lms0509, Jun 14, 2002.
  1. lms0509
    lms0509 New Member
    I have a 1986 bounder 34ft RV and it tends to have a pretty loose ride and bounces up and down quite a bit on the roads when going over a pothole, etc... Would having the shocks/suspension checked out help to reduce this or is this a common thing with them. New to RVing have only had since november.
    Thank you
  2. C Nash
    If you have never drove a M/H it takes a little getting used to but, on a 86 I would bet it needs shocks. Remember it is pretty easy to overload a M/H and be sure to load it equal. tire pressure is also very important.
    Chelse L. Nash
    fulltimer03@yahoo.com
  3. Gary B
    Gary B Senior Member
    Hi Ims0509, agree with Chelse, also check the front air bags in the coil springs (at is if its on a Chev P-30) for that size MH you'll need at least 70 PSI and maybe 90 PSI of air pressure in the air bags. Having the air bags properly inflated makes a world of difference in handling on the Chev P-30 chassis. Happy trails GB
